multiple cDAQ Chassis
I will be using multiple cDAQ chassis across a network. Is it better to create a separate DAQmx task for each chassis or combine into 1 large task?
(2,915 Views)
Accepted by topic author NNS-CAO
I have not tested it with multiple cDAQ chassis, but there are many PCI/PXI cards that will not even let you have a task go across multiple cards.
My opinion, I would use seperate tasks for each chassis.  Makes the code a little more modular.
GCentral
(2,898 Views)
Thanks. That was what I thought.
(2,892 Views)
