multiple daq boards
HI,
  I am moving forward with my project thanks to help from these forums and I try not to post on here asking for help, however I can't find a clear enough answer to my latest issue.
I have multiple USB DAQ's all the same model.  However when writing my labview programs they refer to Dev2.
Is there a way through labview to either poll for connected boards, or to group DAQ's in NI MAX so that they have the same virtual name?
(2,710 Views)
Accepted by Chrispbrown2255
You can use a DAQmx property node to get a list of all installed devices. Each device has to have a unique name.
(2,693 Views)
Thanks Dennis,
  It wasn't the exact solution that I was looking for, it's better :D.
Thanks for pointing me in the right direction, I found an example relating to the DAQmx property nodes (which I didn't know existed), and built from that.  Unfortunately the example I found wasn't too clear so I'll add a clearer explanation to the examples comments.
(2,656 Views)
