07-20-2015 09:05 AM - edited 07-20-2015 09:07 AM
Hello
I want to just write a simple Labview program that would take an input from user (The input must be limited e.g creating a drop down menu). Then based on this input, it must ask user to enter other inputs. for example.
Input 1. can be either a colour , a month or a fruit.
Input 2. If input 1 is colour, then drop down menu should take Red, Green, Orange and Yellow from user. If Input 1 is month, it should ask for one of twelve months and so on.
In the third step I am going to use both of the inputs.
Take the example from snapshot.
I would like if you could indicate me an easy method to use this, or should I create a text / excel file or some sort of table to implement this.
07-20-2015 09:13 AM
07-20-2015 09:24 AM
Thats fine but I want that. If user selects Month from dropdown menu 1, The second dropdown menu should automatically show just the names of months.
If user selects Colours from dropdown menu 1 , the second dropdown menu should only show colour names.
I hope you understand my problem.
07-20-2015 09:30 AM
You just write the the Strings[] property for the ring to change the possible values. You can use the first menu ring and a case structure to decide what to populate the second menu ring with.
