multiple timer+saving to file
Sorry, let me start over:
I was browsing old threads and I found a VI to create a timer. Please see "before.vi" However, I didn't want it to output onto an indicator, instead, I wanted to output the total time onto a file, and I changed it to "after.vi".
However, that change doesn't work. Could you guys advise on what I should do to get it to work as I want it to? I think I can figure out the cascading thing in the OP after that.
Message 11 of 17
(1,298 Views)
See comments above
"Should be" isn't "Is" -Jay
Message 12 of 17
(1,293 Views)
How would I get the values to "save" over to the stop event?
Message 13 of 17
(1,291 Views)
Accepted by johndoe3344
wire them
Message 14 of 17
(1,288 Views)
Got it!! Thanks!!!!
Message 15 of 17
(1,286 Views)
Those tunnels set to use default if value if unwired can be a pain in the neck sometimes.  Smiley Very Happy
I've found its a good practice to use them sparingly and only for states that really don't matter.  Glad to help!
Message 16 of 17
(1,283 Views)
I knew my comment would be proven true eventually! Use default value takes down another!
Message 17 of 17
(1,278 Views)
