myRIO USB file path
I am creating data acquisition VI's for myRIO that save to a USB thumb drive connected directly to myRIO. However, for whatever strange reason sometimes myRIO changes the USB drive designation from say (U:/ to V:/) and recently from V:/ to W:/ . I am wondering what would cause myRIO to behave this way so I can avoid this happening in the future.
(6,119 Views)
Greetings nfortier,
Windows is the one in charge of assigning the drive letter to any device that connects to the PC. The OS looks at the device ID and checks the registry and assigns the drive letter based on that, if there is no pre assigned letter it will assign the first unused drive letter. Take a look at this tread for more information and a method that can help you change the drive letter that's assigned to the drive.
Alejandro C. | National Instruments
(6,087 Views)
I am aware of this. But specifically myRIO itself seems to re assigning the USB thumb drive. It is connected directly to myRIO via its USB port and thus I would think myRIO would be assigning that pathway. Unless I am misunderstanding something here. It only seems to happen when myRIO runs a VI that needs to save data to a USB thumb drive that it seems to change its default USB pathway. I am just wonder what this is because I have to change the pathway in the VI before I can collect data again.
N
(6,069 Views)
Accepted by nfortier
Assuming you are using the myRIO-1900 then yes, the one assigning drive letters is the myRIO and the way it performs this operation is the same described above (see manual, page 13).
The difference lies in the OS that is running on the device (RT Linux). The process that is mounting things automatically is pretty nested inside all of the other processes on the device.  It's called mdev. Looking on the system folders, check the following locations: /etc/mdev.conf (configuration file), plus, /etc/mdev/automount.sh and /etc/mdev/usb.sh (these files contain rules for mounting devices)
That being said, you can modify the contents of these files to force static drive letters. Unfortunately modifying the default behavior is something we cannot help you with (not recommended), but looking at the bright side, you can back up the files and play around with the options, plus, there is plenty of documentation out there to figure things out.
I hope this helps
(6,059 Views)
Hello, have you solved your problem? Can you tell me how to solve it in detail?
(2,241 Views)
