06-13-2014 12:18 PM
06-13-2014 12:34 PM - edited 06-13-2014 12:37 PM
I can't speak specifically to the myRIO, but for I2C in general, you will send the following (Note: Bold items are responses from the slave, the normal font are the bits you transmit):
Start Bit -> Slave Address (Write) -> Slack Ack -> Register Address (0x11 in your case) -> Slave Ack -> Repeat Start -> Slave Address (Read) -> Slave Ack -> [Read Data (8 bits) -> Master Nack]
To do a repeated read (if your device supports it), the bracketed segment gets replaced with:
[Read Data (8 bits) -> Master Ack -> Read Data (8 bits) -> Master Ack .... Read Data (8 bits) -> Master Nack]
If you have a more specific LabVIEW I2C related question, post the code you have so far and I can take a look at it.
06-13-2014 01:05 PM
Thanks for the fast reply HappyAsthma !
Below is the VI i'm sing and its not working in the current state. Should I wait for some time between the write and read event?
06-13-2014 01:21 PM - edited 06-13-2014 01:40 PM
No. You should not need to wait (the exception being if you were manually manipulating the clock). Per specification, you send a bit every clock cycle.
And I cannot open the VIs specifically since I don't have the library/drivers installed, but try using the Write Read VI to do your reads instead of manually doing 1 write and then 1 read:
http://zone.ni.com/reference/en-XX/help/373925A-01/myrioreference/myrioref_i2cwriteread/
You should send the Slave Address, Bytes To Write == 0x11, Byte Count = number of bytes you want read (your device may need a special value to be set in a register to do incremental "burst reads")
EDIT:
My guess (without seeing the VI code) is that the Write VI and Read VI are sending the STOP bit automatically once they are done writing/reading all bytes. The Write Read VI is likely configured to Write the byte(s) and then immedately Read some byte(s) before sending the STOP bit.
06-13-2014 01:40 PM
Aaaaah I get it now! So simple 🙂
Thank you HappyAsthma!
06-13-2014 01:41 PM - edited 06-13-2014 01:42 PM
Glad to hear it! 😄
Don't forget to mark the solution!
07-03-2014 05:09 AM
Is there any NI modules which contains analog measurements and digital measurements and frequency and also main I2C communication in one module???
Please give a suggesion if any third party modules also including above parameters.
07-03-2014 06:03 AM
duplicate post, continued here!
11-10-2014 02:43 AM
Sir,
11-10-2014 06:33 AM
Just because you bumped several old threads related to i2c doesn't mean we're willing to do your homework for you.
Start a new thread. Tell us what you've done. Tell us where you're stuck. Ask for help. Do NOT ask us to do your work for you.
