open all files in folder as path array
I am trying to open a folder of jpeg images and save the path as an array so that I can manually display them and step through them. What is the easiest way to open a folder of images and save the images as a path array?
Message 1 of 13
(22,986 Views)
Just use the List Folder function. That returns an array of filenames which you can then loop through and use Build Path to create a full path.
Message 2 of 13
(22,979 Views)
There is a List Folder function in the Advanced file palette.  It will list all files in a folder or the list can be filtered.  I use this in my
Slide Show program.
Lynn
Message 3 of 13
(22,975 Views)
One of the LabVIEW functions is called "List Folder". This VI will return an array of files that match a specific pattern. You can use this to search for all files of a specific type. From here you can use "Build Path" to turn each of the filenames into the full path or just "String to Path" to convert all of the filenames into relative paths.
     Rob
Message 4 of 13
(22,973 Views)
Hi I just did what you did in the example, but the loop outputs an array of file names rather than outputting one filename at a time. How do you make it output the names sequentially to the file path input? I can't wire the file path array to the file path input.
Message 5 of 13
(22,010 Views)
It's not clear what you exactly mean. Check the attached vi if it is the one which you are looking for..
Nitzz
(Kudos are always Welcome, Mark as a solution if it is the One;))
Message 6 of 13
(22,007 Views)
Place the Path input in a loop. 😉
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 13
(21,998 Views)
OK, I managed to fix the problem. My VI was already in a for loop. When I copied the example, I made a new loop inside the main loop for the path builder, which did not work. The image processing loop needed to run once for each image. I placed the list folder icon outside this image processing loop, and placed the build path icon inside it, this did the trick. Now I have run into unrelated problems to do with building a report file.
Message 8 of 13
(21,990 Views)
I know this is an older post, but I am trying to create this array of file paths/names and it completely populates the array with all my file names, but then a dialog box comes up asking me to select a file.  I don't know why it is coming up and I don't want it to.  Does anyone know what may be causing this and have a way to fix it?
Thanks.
EDIT: Actually nevermind... I figured it out. It was a rogue sub VI that was off screen that was causing the dialog.  Thanks though!
Message 9 of 13
(21,605 Views)
i tried to run your vi but i keep getting an error message which says file is not a resource file.
Message 10 of 13
(15,904 Views)
