package installer error
I am using LabVIEW 2014.   I want to create a package installer using the application builder.   I set it up and tried to build it.  I get an error during the build.  I do not get an error code just this message in the details:
An error has occurred. Expand the Details section for more information.
Click the link below to visit the Application Builder support page. Use the following information as a reference:
Create Folder in Create Directory Recursive.vi->IB_MSI.lvclass:Engine_InitializeDistribution.vi->IB_MSI.lvclass:Build.vi->Installer.lvclass:Build_from_Wizard.vi->AB_UI_Frmwk_Installer.lvclass:Build.vi->AB_UI_FRAMEWORK.vi->CDK_Item_OnDoProperties.vi->CDK_Item_OnDoProperties.vi.ProxyCaller<APPEND>
C:\Users\mfgeng\Desktop\WORKING_FOLDER\builds\OEMSP  \OEMSP PWBA Software Application Installer
Any ideas where to start on determining the problem?
(3,962 Views)
Accepted by Idon'thaveanalias
I just found this other entry that might help you:
http://forums.ni.com/t5/LabVIEW/Error-1430-occurred-at-Create-Folder-in-Create-Directory/td-p/104149...
Another thing to try is to changed the "Installer destination" in the installer build specifications to resolve the problem. Hope it helps,
Luis G.
(3,917 Views)
Thanks for the link.   I redid everything and that solved the problem.   Not sure what the real issue was.
(3,864 Views)
