01-21-2014 11:31 PM
I've a problem using panes with a vertical splitter. When I wan't to scale only one object (a tree) in a pane I get the error 1358 when setting programmatically the splitter position. I am using it to expand/collapse the pane. Without using the option "Scale Object with Pane" on the tree object everything works fine but without resizing the tree object automatically. The error explanation says that I can set the minimum size of the pane but it is already set to 1/1. and I wan't to set the splitter position to 10.
What's going wrong in this case?
Best Regards,
Joachim
01-22-2014 02:57 AM
Hi Joachim
Can you post an example VI ?
02-14-2014 08:00 AM
Hi Neil,
sorry for the delay. Attached is an example with which the error 1358 can be reproduced.
Best Regards,
Joachim
02-19-2015 01:24 AM
