parse serial data 2 bytes at a time
I'm acquiring 8 bytes of serial data and I would like to parse the data into 2 bytes of data so that I end up with 4 different temperature measurements. I tried many things that I found within the forum but I can't get it to work. The VI I attached is using the scan from string function but I'm not very familiar with this function. My defaulted my serial data so that you can see the data I'm receiving.
Thanks in advance for your help
Lowski
Message 1 of 11
(3,347 Views)
Do you know what the format of the data is supposed to be?
Bill
CLD
(Mid-Level minion.)
Message 2 of 11
(3,333 Views)
Yes the processor is spitting out data in binary (8 bytes) my output data will be displayed in decimal value
Message 3 of 11
(3,327 Views)
Looks like 8 bytes of binary data. Try unflatten to an U16 (or I16) array and index the four elements.
Do you need to apply some scaling?
Is it little or big endian?
What range of temperatures do you expect from the default data in the current string indicator?
Message 4 of 11
(3,325 Views)
I'll give that a try...
Yes I do have to apply some scaling, it lil Endian, and I'm expecting to read temperatures upto 210C
Message 5 of 11
(3,317 Views)
Sorry I meant BIG Endian
Message 6 of 11
(3,315 Views)
Accepted by lowski
See if this gets you started. You need to figure out the scaling yourself.
Message 7 of 11
(3,311 Views)
Thanks for your help altenbach! Yes this is exactly what I need...However I've applied my scale factors and I noticed that the I get the correct readings (~24-26C) for all three measurements but then I get really odd readings which tells me that I'm not synced at all. You probably noticed which I should of mentioned in the beginning, there is are 2 bytes of data at the end of the string (0xBEEF) that was added to use as a sync so that I know whats the next 2 bytes and so on are. How can I do this in LV.
Thanks again for your help!
lowski
Message 8 of 11
(3,304 Views)
Sorry, I don't do serial,....
You probably need to slow down the loop and query the number of bytes at port before reading. At what rate are the string arriving? Maybe you should just buffer the data and parse whenever your end of string marker is detected. I am sure somebody can give you more precise advice.
Message 9 of 11
(3,298 Views)
Thanks for the help! I think buffering my data and then parsing it is the way to go, I'll see what I can do
lowski
Message 10 of 11
(3,291 Views)
