parsing mid string data
I'm pretty new to LV and I'm trying to figure out a way to parse data from the middle of a string set. an example of the data: 854560@67042850@600,000@151168390748@1000477480@00000000000000000
From this I'm trying to extract the first 6 digits (854560) and the 10 digits (1000477480). The length of the other numbers changes from data set to data set that I'm working with but the "@" symbols are always involved. So, I'm wondering if there is a method to extract the left 6 and between the 4th and 5th @ symbol.
Thanks.
(3,226 Views)
Accepted by cb4004
If you're always going to have @ symbols as a delimiter and it will always be the same number of elements, you can just convert to an array using "@" as the delimiter and pull the first and 5th elements.
Cheers
(3,211 Views)
A LabVIEW function that simplifies problems like this is "Spreadsheet String to Array" (which should maybe be called "Delimited String to Array" instead). Set your delimiter to @ and you'll get an array of values, with all the @s removed. Index out the desired array element.
(3,209 Views)
