password protection of block diagram works only for 1st time
Hi All
I have set of VIs which I ahve password protected(using the same password), through VI properties --> protection-->Password Protected. I closed the LabVIEW and tried to reopen any of the VI.
The VI asked for the password(say a.vi) . I provided password and then just closed the VI. Again I tried opening a.vi's block diagram , it did not ask me for password . 😮
Also , after providing password for a.vi , if I am closing it and trying to open BD of b.vi , its not asking me for passowrd.
Is this how the password functionality works? It should ask me password for each VI when everytime I am trying to access it BD.
Message 1 of 8
(3,862 Views)
Accepted by LV_user1
Hi LV_user,
LabVIEW stores the password in an (internal) cache once you have input the password. It keeps the password in memory for this LabVIEW instance. When you restart LabVIEW you have to input the password again…
This behaviour is explained in the LabVIEW help, please read it
Message 2 of 8
(3,840 Views)
as Gerdw point
you just do not restart your labview
restart your labview after make passwords (not just close vi and open agian
Message 3 of 8
(3,820 Views)
Hi Hatef,
did you read the help as linked above?
You only need to "clear [the] password cache"…
Message 4 of 8
(3,810 Views)
Got it !!
Thanks for the help!
Message 5 of 8
(3,598 Views)
Hi User,
it took you more than two month to get it? 😄
Message 6 of 8
(3,564 Views)
I'm guessing the automated reminder from NI on open threads sent OP an email asking if the issue was solved, reminding them that they hadn't replied or making a solution.
Message 7 of 8
(3,540 Views)
Appologies for the late reply...
I got it long back but forgot to marked it as solution.....
I was away from the NI forum for couple of months ... Smiley Sad
Spoiler
Message 8 of 8
(3,509 Views)
