picture icon
i am studying some vi .in 1 vi there is an picture icon .but i cant understand how this icon appears bcz i copied n jpeg on block diagram so it takes it as a decoration . that icon is an indicator bt kindly tell me how can i make one same in my vi.
Message 1 of 9
(3,419 Views)
Accepted by ghamad
That's a 2D Picture Indicator as shown on the Block Diagram.
On the Front Panel, get if from Controls > Modern > Graph > Controls > 2 Picture
Once it's on the Front Panel, go to the Block Diagram and there it is.
Message Edited by Broken Arrow on 10-08-2009 10:57 AM
Richard
Message 2 of 9
(3,403 Views)
Can you explain a little more clearly what you are trying to do?
Also, can you use your entire keyboard and type in clear English for your question?  There is no need to speak in "text message".
"bcz "= because
"bt" = ??????
"copied n jpeg"=  copied a jpeg ??
Message 3 of 9
(3,399 Views)
Ravens Fan wrote:
"bt" = ??????
"bt" = "but"? If so, it saves a whole letter.
"copied n jpeg" = "copied it in as a jpeg". ??
I feel for the teachers that have to grade papers with this garbage in it.
Richard
Message 4 of 9
(3,397 Views)
I don't, grading is easy when they fail.  You deserve a zero until it is done properly, don't waste my time imaginary student.
P.S. Not a teacher, never going to be one.
Message 5 of 9
(3,365 Views)
thank you broken arrow for your help.currently i am working on some project, your guidance will be required.do you have any experience in data acquisition.and i hope now i am clear to all those having problem with my language . by the way thanks every1 for workin so hard n understanding my txxt...lol
Message 6 of 9
(3,358 Views)
ghamad,
I am pleased that my guidance will be required. Yes, I have experience with data acquisition. I am currently employed at ... h e y   w a i t   a   m i n u t e.
Richard
Message 7 of 9
(3,341 Views)
ok thanks.... well i am working on some system that have around 16 to 20 pressure points. now i have to measure that pressure points continuously . what would you suggest either i go with ni daq cards or the canbus solution. the problem is that in using ni daq card the cost increases compared to canbus but in canbus tech only one pressure sensor can send data to computer at one time  so do you think its feasible  to work with can bus if pressure sensors continuously send data .
Message 8 of 9
(3,294 Views)
also if you have any trouble understanding what an Icon is you can use ctrl-h and it will tell you what it is and then you can search for it under the controls palette
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 9 of 9
(3,278 Views)
