plot name same as file name
hai ,
good morning. i would like to know is it possible than when i open a text file to be plotted as a graph (from pop up directory) the plot name to be same as the file name which i opened. for example when i open file (test1) to be plotted. the plot name on the graph will be test1. the file name is not fixed. thanks
regards
shamaran
Message 1 of 8
(3,493 Views)
Its easy
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 2 of 8
(3,481 Views)
hai ,
thanks for the reply but that is not the solution that im looking for . the real problem is when i click the file name from choose file to read this name should be the plot name. plz refer to the picture below . when i choose the file test1 the plot name should change same as the file name(test1).
thanks
shamaran
Message 3 of 8
(3,464 Views)
Try this
Message 4 of 8
(3,461 Views)
Front panel
Message 5 of 8
(3,460 Views)
You need to get the file name from the file path and give as a plot name.See the attached example.
Message Edited by Baji on 11-06-2009 12:33 PM
Balaji PK (CLA)
Message 6 of 8
(3,458 Views)
Solved?
Message 7 of 8
(3,410 Views)
Another possible approach for naming plots could be using waveform datatype. The waveform datatype includes attributes which could be read/written by get/set attribute. The attribute for the plot name would be NI_ChannelName.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 8 of 8
(3,403 Views)
