position of the signal wave from analog input data acquisition
i have a problem with my data , so basicly i can read every 4 analog input channel on my signal wave , but is there any chance that i can change the position of every signal on the waveform chart , how can i change position of every signal so i can read the sign comfortly. Thanks . I really need your help . 05Nop2022.bmp
(897 Views)
Hi Celine,
One way I could think of doing it is as below:
(877 Views)
Another option is to use stacked plots...
(862 Views)
iam using ni daqmx assisant , so is there any chance or shoul i change my ni daqmx
(855 Views)
Hi Celine,
I guess you are using the DAQAssistent ExpressVI!?
How is that related to your problem of showing plots on a chart/graph with some "offset" between them?
Why don't you attach your VI (or a simplified version of it) so we can give better suggestions?
Have you tried to implement both suggestions you got so far?
(820 Views)
