possible bug in match pattern in string for dot and Special Character
hi friend recently i find some thing in match pattern string that it look like bug I want to know labveiw expert opinion about it
the possible bug is that
did you ever try to match (.) dot for use it in regular expression ? this icon could not find dot inside the string ?!!
also I think what if we try to find a character inside a string that is piece of Special Character
for example how you can use this icon for finding \b inside string like( hatef\blabview )?!
(5,539 Views)
@Hatef wrote:
" how you can use this icon for finding \b inside string like( hatef\blabview )?!"
What "icon" are you talking about?
Can you post a VI that contains examples of strings and how you are searching them that makes you think there might be a bug?
(5,536 Views)
this is vi for match . and \b
(5,508 Views)
And why do you think there is a bug?  What do you expect the results to be?
Did you read the help for Match Pattern, and drill down and find the help article "Special Characters for Match Regular Expression and Search and Replace String".
A period means "Matches any single character except a newline character. Within square brackets, . is literal."
A \b means "
  • \b - Represents a word boundary. A word boundary is a character that is not a word character adjacent to a character that is a word character and vice versa. A word character is an alphanumeric character or an underscore (_). For example, \bhat matches hat in hatchet but not in that. hat\b matches hat in that but not in hatchet. \bhat\b matches hat in hat but not in that or hatchet."
The results seem to be exactly what the help file is describing.
(5,496 Views)
than you for answer  RavensFan but I get a bit confused with your answer  could you make a simple example vi to solve this problem?
problem is that
find( .) position (or offset) inside this string(  hatef.labview)
find (\b ) position (or offset) inside this string(  hatef\blabview)
I try use match pattern and I could not solve it
your solution should find position or offset 5  for . and \b
(5,483 Views)
Accepted by Hatef.fouladi
[.] to find the period
\\b to find the backslash b
(5,462 Views)
thank you for your answer
it realy work
(5,454 Views)
