10-22-2018 10:22 AM
I have installed LabVIEW 2016 on my laptop, but even though i have windows 10 and the software should be compatible with it, the app does not launch. Can i do something to fix the problem?
10-22-2018 10:53 AM
What kind of antivirus are you using?
10-22-2018 11:36 AM
McAfee LiveSafe
10-22-2018 12:16 PM
Incidentally, LabVIEW 2016 is perfectly compatible with Windows 10 (x64) -- I have it running on my laptop in this configuration.
10-22-2018 12:32 PM
@silvanaioana wrote:
McAfee LiveSafe
Try to see if disabling it makes any difference (some AV are quite intrusive, see e.g. here).
Does it work better if you run it as administrator?
Does it show up in the task manager even if the window does not show?
Do you see any errors in the windows log?
10-22-2018 01:15 PM
The version of labview i have is in file 1, in file 2 is the message i get when i try to launch the app, in 3 are files that appear in MAX folder. I had installed a while ago other version and when i uninstalled it some file remained and i was not able to erased them, some of them are in pic.4
10-22-2018 01:50 PM
Are you sure this is a legitimate copy of LabVIEW? I wouldn't necessarily trust downloading something that wasn't coming from NI. I know it says "academic" verison, but those prices are super cheap.
10-22-2018 02:00 PM
it comes from NI, my university gives us access to this versions, and we can only use them for learning, nothing more
10-22-2018 03:00 PM - edited 10-22-2018 03:02 PM
From your other post, you are in Romania and according to this page "Onthehub" is for US and Canada. (From the link, it seems your university has a special arrangement (but why are the prices in dollars?) Seems legitimate, though.
You might have to ask whoever gave you this link. Is this a campus resource?
Did you reboot after installing?
Was there ever another LabVIEW version installed on that computer that did not get removed correctly?
What does the NI license manager say?
Did you ask around? Do your classmates have the same problem?
10-22-2018 04:00 PM
I'll "echo" Altenbach's latest post, and my earlier post, but ask the questions a little differently:
