03-12-2015 09:12 AM
Hi everybody,
I`m going to try to be clear, but I have juste one problem with the coordinate about a rotate rectangle.
So, first I have this data, and when I put in Excel I have a right rectangle.
SO now I know that I have to modify the data with the rotation, It`s what I did.
It worked very well, I tried with graph and to modify the degree of rotation it was perfect I had good rotated rectangle.
My next step and final step was just to put the coordinate on excel and reproduce the same rectangle on one graph in Excel.
And it`s there that I met the problem.
I have no Idea why, and I don`t see what to change to fix that......
I now that just one rotation of 90 degree it`s enough to correct the position but where can I change something?
If somenody know something about that or have the solution, you`re welcome.
Sorry about this big post but I think is more clear with picture than more text.
Thank you again for your answers (in advance)
Maxime
03-12-2015 09:19 AM
Direction of rotation?
In Excel, it looks like a postive rotation causes it to rotate clockwise.
I didn't dig into your math, but in a lot of programs (like Autocad), a positive rotation angle is counter clockwise following the right hand rule. Where 0 is the + X axis and a line from there rotates towards the + Y axis with a + angle.
03-12-2015 09:23 AM
Yes Thanks you a lot.
We just found the solution at the same time.
You`re right!!!!!
I`m feel really relieved
