problems loading .NET assemblies
Hello eveyone,
I got a dll(C#) form a instrument vendor and I want to use this assembly file to build a automation measurement program.
However, I encounter a issue that I can't load this dll correctly, It showed "An error occured trying to load the assembly"
I had tryied this steps in belowed pages, but no luck.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIQoCAO&l=zh-TW
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8XnSAK&l=zh-TW
The assembly file is attached.
Please help me. Thank you.
(211 Views)
Accepted by wayneshen3113
You assembly was targeted exclusively for x86, but you are in x64 environment: (and by the way for .NET Frameworks 2.0).
I recompiled it for AnyCPU using .NET Framework 4.8.1. Also added "Test" method. Version increased to 1.0.0.1, now should work:
Try this one from the attachment.
(193 Views)
It didn't load for me in LabVIEW 2020 SP1 32-bit. And JetBrains dotPeek claimed it was linking to MS .Net 4.0.0 but I did not investigate beyond that.
Rolf Kalbermatter
My Blog
(175 Views)
Hi Andrey,
wow!  It is working now.
Thank you~~~~
(141 Views)
Hi rolfk,
Thank you for willing to repond my problems.
(139 Views)
Yes, this is "legacy" assembly, in order to get this running you might need to place LabVIEW.exe.config next to LabVIEW.exe with content something like this:
<?xml version ="1.0" encoding="utf-8" ?>
<configuration>
   <startup useLegacyV2RuntimeActivationPolicy="true">
      <supportedRuntime version="v4.0"/>
   </startup>
</configuration>
Refer to
Loading .NET 2.0, 3.0 and 3.5 Assemblies in LabVIEW
as well as <startup>-Element and <supportedRuntime> element.
But rather than dealing with legacy stuff in this particular case was more simple to rebuild with latest sdk (at least for me).
@wayneshen3113 wrote:
Hi Andrey,
Thank you~~~~
Glad to see that this working now.
(119 Views)
