programatically change number of the time led blinks
How can I do it? in a labview I want to create a for loop, in which if I enter 6 , led blinks 6 times..
(3,015 Views)
(3,015 Views)
Where are you getting stuck? Can you post what you've tried so far?
(2,998 Views)
Accepted by topic author Canucks.canucks
Start with a FOR loop with a shift register that holds a Boolean.  Each iteration, invert the Boolean (NOT) and update the LED indicator.  Have a wait in the loop so that you can see the blink.  Have the loop iterates twice per blink.
GCentral
(2,989 Views)
The problem is when my Boolean / led turn true /on it stays like that and doesn't go back to off .
(2,978 Views)
Then show is your code so we can troubleshoot your code.
GCentral
(2,971 Views)
