"Error 0xBFF69012 Attribute value is out of range" for Point Grey Grasshopper2 GS2-GE-50S5M
Trying to get the above camera to work in MAX. Currently running on LabView 2010 SP1 with Vision Acquisition Software August 2010.
Error shown: Error 0xBFF69012 Attribute value is out of range
Camera runs perfectly fine on supplied Point Grey software. Point Grey Image Filter Driver installed. Windows firewall disabled. Ethernet card (http://www.sonnettech.com/product/prestogigproec34.html) supports Jumbo Frame.
Have read through the following to no avail:
http://digital.ni.com/public.nsf/allkb/FCE7506A3AF7636C862576240072716D
http://digital.ni.com/public.nsf/allkb/A0A1CE4704265BF2862578CA007A4CF8
How do I know if there is a problem with the XML file?
What are the possibilities that this camera is not compatible with IMAQdx?
Thank you.
(5,014 Views)
Tried using the Camera Validator test (http://digital.ni.com/public.nsf/allkb/EBE3BBBEF4FEA92786257225006FF242?OpenDocument) with the /attributes argument.
Attached is the report. Some of them failed. Can anyone identify the problem?
Thanks.
(5,006 Views)
Original firmware (1.21.3-00) had two compatibility issues:
Attribute: CameraAttributes::ImageFormatControl:: PixelColorFilter
        Display Name: Camera Attributes::Image Format Control:: Pixel Color Filter
        Description: Type of color filter that is applied to the image.
        ToolTip: Type of color filter that is applied to the image.
        Type: 0x4
        Units:
        Availability: R
        Representation: 0x0
        Visibility: 0x2000
        Streamable: false
        Range: {BayerRG = 0x0, BayerGB = 0x1, BayerGR = 0x2, BayerBG = 0x3}
        Current value: UnknownEnumValue
        Validating current value: FAILED ERROR: (Hex 0xBFF69012) Attribute value is out of range.
        Unable to set current value
Attribute: CameraAttributes::TransportLayerControl::GevSCPInterfaceIndex
        Display Name: Camera Attributes::Transport Layer Control::GEV SCP Interface Index
        Description: Index of network interface to use.
        ToolTip: Index of network interface to use.
        Type: 0x1
        Units:
        Availability: R
        Representation: 0x11
        Visibility: 0x8000000
        Streamable: false
        Minimum: 0
        Maximum: 0
        Increment: 1
        Current value: 1
I updated the camera to the latest firmware (1.23.3.0) and the GevSCPInterfaceIndex compatibility issue was solved.
Any idea why a monochrome camera would have the PixelColorFilter?
(4,984 Views)
Accepted by topic author A.Low
Problem solved in unreleased firmware version 1.25.3-00.
Contact Point Grey for this firmware.
(4,974 Views)
