"Variant To Data" fails to convert a variant to I32.
I read an integer from a database which was returned as a variant.
The value is 25, but if the VI converts it to I32, the returned value is 0.
Why does it happen? How can I fix it?
Message 1 of 14
(4,897 Views)
Hm, i would say that you have an issue with the numeric value in the variant, not with the cast.
Attached you find a VI combining different numeric data types for casting but i always received the expected value.
Are you sure that "Variant To Data" does not return an error? Have you already probed the variant to check if it contains the expected values?
Norbert
Norbert
Expert: Geometry
Message 2 of 14
(4,893 Views)
here's a snippet that return the type of data contained in a variant.
hope this helps
Epictetus
Antoine Chalons
Message 3 of 14
(4,888 Views)
Norbert
I see
Error -2147467261 : ConvertDBDataToNmtData[V.01].vi->Impl_ReadNMTFromAccessDB[V.02].vi "Wrong Pointer"
LabVIEW:  (Hex 0x80004003) Invalid Pointer.
This error happens when "Variant To Data" tries to convert a variant matching DB NULL value to another type.
How do I check a NULL value?
Message 4 of 14
(4,887 Views)
What is the version of LV you are using?
Norbert
Expert: Geometry
Message 5 of 14
(4,882 Views)
2009 SP1
Message 6 of 14
(4,880 Views)
Can you look into MAX and find out which version of the Database Connectivity Toolkit you have?
Norbert
Expert: Geometry
Message 7 of 14
(4,871 Views)
Accepted by topic author iCat
Try to use Database Variant To Data instead of Variant To Data:
Message 8 of 14
(4,862 Views)
hope this helps
this doesn't help?
Epictetus
Antoine Chalons
Message 9 of 14
(4,859 Views)
@TiTou wrote:
hope this helps
this doesn't help?
Since I'm a LabVIEW beginner, I don't know what that even means.
Message 10 of 14
(4,834 Views)
