reading emails from gmail by labview
Try:
https://<username>:<password>@mail.google.com/mail/feed/atom
Where username and password should (obviously) be your email username and password.
From there use an RSS parser.  Here is a forum thread with such discussion on Lava: http://lavag.org/topic/10540-get-rss-feeds-through-labview/
Message 11 of 40
(6,177 Views)
Is there an internet mail server that don't have SSL?
J
Message 12 of 40
(6,156 Views)
Or, Can you read emails from gmail with SSL off?
Message 13 of 40
(6,152 Views)
Accepted by heartware
There may be. You'd have to look around though.
No.
Have you tried any of the available .NET classes? There are numerous ones out there. The free ones are a little flaky, but they can be used to a certain extent. For example, attached is a simply VI that uses the free .NET class from http://csharpmail.codeplex.com/. There is a problem with that class in that getting the Date property of the message will sometimes generate a .NET error, but you can get the date by getting the message body and using string functions to find the date.
Message 14 of 40
(6,146 Views)
Thanks! This one will work for me. Can you delete the mails as you read them?
Message 15 of 40
(6,139 Views)
You can configure that in your Gmail settings.
Message 16 of 40
(6,126 Views)
Could you please correctly mark which post really solved your problem. I hope it's smercurio's post.
Thanks for your understanding,
Mathan
Message 17 of 40
(6,111 Views)
you can do this
Message 18 of 40
(6,096 Views)
I do not have the same menu as yours. Is there other ways to unmark?
Message 19 of 40
(6,067 Views)
 I dont know whether there is another way but you can try reporting it to the moderator.
Message 20 of 40
(6,026 Views)
