regexp to capture numbers
i have lines containing numbers looking like this : \s\s\s1025.205\s\s\s-0.002\s\s\s520.125\s\s\s0.001\s\s\s\s
number of \s to separate is not constant
which expression can i use to obtain numbers between "\s"
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 1 of 8
(3,007 Views)
This worked for me
Tim
GHSP
Message 2 of 8
(3,003 Views)
thanks
how can i add the sign  ?
Tinnitus
Message 3 of 8
(3,000 Views)
@tinnitus wrote:
thanks
Tinnitus
I do not understand your question?
Do you just want to add it to the result? If so just concatinat the result and the ?
Tim
GHSP
Message 4 of 8
(2,998 Views)
Sorry,
with this regexp did you recover the minus of  -0.002 for exemple ?
Message 5 of 8
(2,994 Views)
Accepted by tinnitus
This one works sorry I did not notice that.
Tim
GHSP
Message 6 of 8
(2,984 Views)
You can add [\+\-]? in front of aeastet first regex, alternate regex solution is [\+\-]?\d+\.\d+
Ben64
Message 7 of 8
(2,980 Views)
Presuming that you would want to perform some mathematical operations on the values, you may want to consider using "Scan from String"
Now is the right time to use %^<%Y-%m-%dT%H:%M:%S%3uZ>T
If you don't hate time zones, you're not a real programmer.
"You are what you don't automate"
Inplaceness is synonymous with insidiousness
Message 8 of 8
(2,970 Views)
