remote front panel cannot load in browser but works from labview
Can you recheck whether Run Time Engine plug in is installed for IE8 or try it on  any other browser..Also disable if any antivirus runs in that machine.
Message 31 of 34
(1,340 Views)
hi everybody,
i am using labview 2010. i have the same error that occured in this post. i checked eveything following the post. i think i am doing everything right but there is a problem somewhere. i have the same version of labview runtime engine installed in the client computer. i can access the remote panel from the browser if the client computer is on the same subnet. but i cannot do the same thing when the host computer has a static ip address which makes the VI accessible through the internet. the fatal error message is being displayed on the web browser every time i try to access it. the root directory setting is the www folder and i have a * in the visible VI field. i cannot possibly begin to understand  what the problem is. i would be very grateful if any body helps.
thanks in advance.
neeraj
Message 32 of 34
(1,326 Views)
Hey Neeraj,
Have you taken a look at this link?
http://digital.ni.com/public.nsf/allkb/7023359DE2FFEF7A862572B8007A6126
It has a lot of information as to what to do when you can't find your page with remote front panels.
Hope This Helps,
Doug B
Applications Engineer
Message 33 of 34
(1,307 Views)
Try to desactivate your antivirus, it should work.
Lily
Message 34 of 34
(990 Views)
