rms of simulated signal
Hi guys, I went trough all topics of RMS calculation and still stuck to it. Need to calculate RMS(root mean square) of the output signal (named as "OUT" on the block diagram and front penal) . I do really miss something on my way but can find out what. Please give me a hand!
Thanks!  Your help is highly appreciated!!!
(2,925 Views)
how about this?
What are you missing?
Sorry for not looking into your zip..
Greetings from Germany
Henrik
LV since v3.1
(2,892 Views)
It looks like you are already getting the RMS.  Where is your problem?
GCentral
(2,880 Views)
Accepted by zuzi
Dear zuzi!
I took a look on your application.
It's real nice, but the calculation of RMS should not be implemented in the Control Simulation loop, since the calculation will be dune for each point, as it can be ssen on the graph indicator, when you run the code.
I made some modifications, and used the Collector function from Uilities palette int the Simulation palette. This function makes possible to collect the data, and make the processing on it after the simulation completed.
Please find your code attached.
If you have any questions, don't hesitate to ask.
BR,
CLA, CLED
(2,874 Views)
Dear Balazs,
You made my day! My sincere thanks for your prompt response and  professional solution.
Best Regards,
zuzi
(2,848 Views)
Thanks for your help!
Greetings,
zuzi
(2,844 Views)
