rounding numbers to the nearest integer in Excel
Hi GerdW
I have done that in message 6, and it still rounds the numbers.
Best regards
Oesen
Message 11 of 20
(1,129 Views)
Hi Osman,
in message 6 you included a text in the message and in message 10 you wrote something about opening and saving a file (I presume in Excel)...
Please attach the text file as it is created from your VI...
Message 12 of 20
(1,117 Views)
Im a bit confused, but let me explain it in this way.
Now i open a new notepad document, and save it as example.txt in the desktop
I change the filepath to example.txt
I test my VI and get the results below:
Best regards
Oesen
Message 13 of 20
(1,104 Views)
Accepted by topic author Oesen
Hi Osman,
please try the attached VI.
I replaced WriteToSpreadsheetFile with ArrayToSpreadsheetString and WriteText.
Message 14 of 20
(1,100 Views)
Thanks for the help GerdW..
I works now !!!
So i always need to use array to spreadsheet, when i will have some data from a array to excel ?
Best regards
Oesen
Message 15 of 20
(1,094 Views)
Hi Osman,
WriteToSpreadsheetFile should do the same as my example.
But maybe you accidently changed something in that VI?
Message 16 of 20
(1,092 Views)
Hmmm.. i can see that it doesn't include my headers in the excel file now
Best regards
Oesen
Message 17 of 20
(1,082 Views)
Hi Oesen,
ok, I forgot to set the file position after opening the file for saving your data.
Either include a SetFilePosition after OpenFile or write the header data after OpenFile using the same appraoch like me!
Message 18 of 20
(1,078 Views)
Something like this ?
Best regards
Oesen
Message 19 of 20
(1,067 Views)
Change that start enum to end and you will be fine.
GCentral
Message 20 of 20
(1,057 Views)
