07-19-2006 10:33 AM
07-19-2006 10:54 AM
There is currently no way, with the Report Generation VIs, to save the image files for an HTML report to a separate folder. If you think this would be a helpful feature, please submit your request to the Product Suggestion Center, and we will look into possibly including this feature in a future release. For now, the only workaround I can think of would be for you to use the File I/O VIs to manually create another folder and move the image files to it, then use the string manipulation functions to edit the contents of the HTML file to point all image file references to the new location.
As for not generating images, I don't know of an easy way to have an HTML page with images where there are not corresponding image files.
Good luck,
-D
07-20-2006 10:34 AM
I appreciate your comments.
Well, I was hoping there was a way to do so. I guess I will have to try something else.
Thanks a million!!
