sb-RIO support on Labview 2018?
Hi all,
Does anyone know whether the Labview 2018 Robotics module will still support the old 'daNI' 'Robotics starter kit 2' based on the sb-RIO9632?
I have been using LV2015 up until now, but my University no longer supports this version, so I need to switch to the latest LV.
Many thanks
(2,340 Views)
Hi there,
Looking at the required software for the kit here, we know the Real-Time, FPGA and Robotics Modules must be compatible. See the readme files below for the 2018 version of each software product:
LabVIEW 2018 Robotics Module Readme
LabVIEW 2018 Real-Time Module Readme
LabVIEW 2018 FPGA Module Readme
For each there is a 2018 version, and the Real-Time Module requires the 32-bit version of LabVIEW. Therefore, as long as you use LabVIEW 2018 32-bit you are clear to go.
Good luck!
(2,300 Views)
thanks for your help - that is exactly what I needed to know
Cheers!
(2,292 Views)
