07-31-2013 04:28 PM
I'm trying to extract xyz coordinates from a very large file. However, every so often, there is a z coordinate with the phrase NO DATA instead of a value like so:
Is there any way to filter these out?
Any help would be much appreciated. Here is a snapshot of my VI, it seems to be working for files without errors.
07-31-2013 05:19 PM
A brute force method:
07-31-2013 05:26 PM
You don't need to unbundle the error cluster in LabVIEW 2012. The NOT function will take in the error cluster just fine.
07-31-2013 05:33 PM
Oh, yeah - oops. I tried wiring the error directly to the conditional and it didn't work (and the logic was backwards), so I dropped the unbundle in there.
07-31-2013 06:14 PM
How do I make the tunnel out of the for loop conditional?
07-31-2013 06:25 PM
It is new to LabVIEW 2012. But you right-click on the tunnel and check Tunnel Mode->Conditional.
07-31-2013 06:27 PM
Is there any way to do it in the 2011 version?
07-31-2013 06:32 PM
Error case just feeds the array through unchanged.
07-31-2013 06:46 PM
Okay thanks I figured that out. Doesn't that assigns the default value of 0 to the cluster when there is an error? Is there any way to just omit the terms with errors?
07-31-2013 06:49 PM
That omits the terms with errors. In the Error case, the output array is not modified.
