scan from string error
I can't get the exit tunnel of the array in the error structure be solid.  It requires that I 'use default if unwired.'
Message 11 of 13
(478 Views)
You must have one case where you did not wire something into the tunnel.  Did you forget to wire the cluster through the Error case?
Message 12 of 13
(471 Views)
Accepted by chazzchuzz
Message 13 of 13
(469 Views)
