06-24-2009 01:20 PM
I have an application that consists primarily of a tab control. On a portion of one of the tabs, I have various controls: check boxes, radio buttons, text and numeric fields. (see attached snap of tab) These are used to access 8 different registers. I need to expand this to access 32 registers but I don't want to grow the tab to be that large. Not all 32 need to be visible at one time.
I was thinking some sort of scrollable sub panel would be nice where you can view 8 registers at a time, but I don't know how to create one. I read other similar posts that recommend using a splitter bar but I only need this capability on one of the tabs not the whole thing.
Any suggestions?
I'm using LV 8.2.
Thanks.
06-24-2009 10:51 PM
06-29-2009 10:14 AM
Thanks!
I implemented an array of clusters and that works well. I didn't go as far as using a separate scrollbar and controlling the index. I'm able to use the array's built in scroll bar feature to implement what I needed.
However, using the array's scrollbar, when I scroll past the active members of the array, there are additional non-active array elements that are grayed out. Is there a way to have an array not show the grayed out 'potential' array members?
Thanks.
06-29-2009 10:23 AM
