04-12-2010 03:36 PM
I have a SCXI 1000, with a 1100 unit, a scxi 1520 unit and a scxi 1600 unit. Now when I connect it, I only get a "USB not recognize unit".
I have installed NI-DAQmx 9.1 and LabVIEW 9.01 32 bit, do I need more? I have never tried to use SCXI before.
I runs at Windows7 64bit.
Thanks in advance.
04-13-2010 03:42 AM
Try restartting the system and if still does not work uninstall the drivers and reinstall
04-13-2010 04:26 AM
04-13-2010 06:05 AM
did you manually tried addding this new hardware by "add hardware" wizaed in the "control panel"?
Guru
04-13-2010 08:08 AM
04-13-2010 08:09 AM
04-13-2010 08:22 AM
04-13-2010 08:39 AM
Hmm I found this for NI-DAQmx 9.0.2;
The following devices are not supported in NI-DAQmx on Windows 7 (64-bit version) or Windows Vista x64:
Does anyone know if the NI SCXI-1600 works with Windows 7 64 bit, in the new version 9.1?
04-13-2010 01:09 PM
For those USB devices, there are not currently plans to add support for 64-bit operating systems. This is due to incompatibilities between the USB design of these older devices and the USB implementation in 64-bit version of Windows.
04-13-2010 01:15 PM
Thanks, that explains my problems. Well I guess that I just have to go for Windows 7 32bit, instead.
Thanks for your help.
Best regards
Bjarne Pedersen
