send command through serial one at time ???
hello every body ...
I am trying to send linux commnad to my robot through labview ..
i connect it by VISA . bluetooth over USB .
i faced 2 poroble .
1- it keep send the same command all over the time .
2- timeout problms.
my VI attached ..
Message 1 of 18
(5,792 Views)
Hi manesaid,
1 - It is like you have programmed it. So it's not a problem, it's a feature…
2 - That could be realted to your "Data bits" property. Why do you read that at all? What's the purpose of reading the "data bits" setting you already know from wiring the VISASerialPortInit?
You use the TermChar, atleast you have it configured. If that's the case: get rid of that (wrong) property and use a constant (but sufficient high) number…
Message 2 of 18
(5,783 Views)
thanks GerdW
my robot have linux OS .
the only way to talk to it using buletooth over USB .
the part of  Data bit in you coment i don't get it ...
i will explain to you the idea of the VI .
first to log to the robot i enter root
then to opnen the programme in it Ienter the command
the i have list of command i want to do it .
the proble i cant control the flow of the data .
what is want enter the first command wait for respons and enter the second command on wait for the response .
it gust like when you work with terminal or CMD
Message 3 of 18
(5,775 Views)
1.  Use a button and an Event Structure to tell your program when to send the data.
2.  It sounds like your robot is not always sending data back.  Or if it is, it is not more than 8 bytes.  You could use another loop for reading of the serial port.  You may want to take a look at this thread to get some ideas: http://forums.ni.com/t5/LabVIEW/Write-and-read-serial-port-simultaneously/m-p/3106900#M890338
GCentral
Message 4 of 18
(5,757 Views)
Tim's Number 1 idea of using the button and an event structure is excellent. Also you might want to use a simple terminal emulator program to send the robot commands just to make sure you understand what it is doing.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 5 of 18
(5,736 Views)
how i can  conect the button with the envent case . what is the proper way to do it
Message 6 of 18
(5,723 Views)
OK, the first thing you need to do is go through some tutorials to learn about events. NI has several online.
Mike...
LabVIEW Champion
Message 7 of 18
(5,714 Views)
Accepted by topic author manesaid
If you do not know how to use the Event Structure, you definately should go through some of the online tutorials (many of which are free).
3 Hour Introduction
6 Hour Introduction
LabVEW Basics
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
Learning NI
Getting Started with NI Products
But in a nutshell, you simply put down an Event Structure, right click on it and click Add Event Case.  A dialog will open up that will allow you to create a case for the button's value changing.
GCentral
Message 8 of 18
(5,683 Views)
Also, 'Data bits' is not the correct property node to use here. The data bits property defines the number of bits used for the data (normally 7 or 😎 - it's part of the configuration of the serial port.
What you are looking for is 'Bytes at Port' - this tells you the number of bytes in the receive buffer. As others have said though, it is generally better use a termination character if your device is sending one.
(blog)
Message 9 of 18
(5,666 Views)
thank you alot bro ... those links are very usful
Message 10 of 18
(5,636 Views)
