serial termination char is not work
In my serial communication ,the termination char is not work ,when the serial receive '0',it will stop receive other words,so i set the termination char to '0x30',and enable termination char to TRUE,but when i transmit "14023",the receive is ''14023' too,not "140".if someone know the reason,please tell me ,thank you.
Message 1 of 9
(3,150 Views)
Please post your VI or some cutout showing the problem, there's too little information for me (and others) to help.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 9
(3,144 Views)
Hello,xiaojing.If you wanna use customized termination char, you could set it in Property Node of VISA. By default, the Termination char is \n or \r. See the attachment for details.
Message 3 of 9
(3,130 Views)
thank you
Message 4 of 9
(3,074 Views)
What do you want your termination character to be?
You set it for 0x30.  Hex 30 is the ASCII character zero "0".  So of course it is going to terminate on the zero if you are sending it the characters "14023".
Message 5 of 9
(3,065 Views)
You have wired "Read # characters" on the read Visa, i dont remember if that overrides the termchar property or not, but it might.
/Y
Qestit Systems
Message 6 of 9
(3,039 Views)
it could override the termination chars by Read Proverty Node.
And also termination chars could be set in "VISA Configure Serial Port.vi"
Message 7 of 9
(3,037 Views)
thanks,all people,i have resolved this problem.
Message 8 of 9
(3,028 Views)
Please mark the solving post as Accepted solution.
/Y
Qestit Systems
Message 9 of 9
(3,017 Views)
