shift register
what is the fuction of the shift register..??
(2,805 Views)
Read Help
(2,798 Views)
For example,
                             If you want to pass a value between different states when you are working with case structures or for storing a value until the program shut down, you will use shift register. What I have seen in my past experience is, Shift register is one of the function can be used mostly in case if you are going for local variables.
Take a look at example here.
"Don't forgot to initialize the shift register before using"
(2,788 Views)
Or intentionally don't initialise the shift register, if you want to create an Action Engine
_____________________________
- Cheers, Ed
(2,784 Views)
Hi Nst,
In a simple manner, a shift register will be used to hold the previous iteration value.
Hope this vi will be helpful. Run the vi in highlight exen mode u can easily understand.
LV 8.0, 8.6, 2011,2012,2013 WinXP
(2,777 Views)
