sorting array, how to get the new index of the last value ?
Hi all !
I'm using a SubVI which adds a cluter of parameters to an array, and then sort this array depending on one of the parameter in the clusters.
This works fine, thanks to the examples I found in this forum 🙂
but now I'd like to know if there's any way to get at the end the new index of the cluster firstly added.
see VI attached
(2,608 Views)
Accepted by _zeyol_
You are taking the size of the array and inserting the new element at that index this is nothing but build array and a simple build would do this.
In your question I guess you are asking about the index of the element that you inserted after sorting the array, right? In this case you can compare the cluster element you are inserting at the initial with the array of cluster that you get after sorting the array. So this will give you the index of the element that you are inserting initially.
(2,603 Views)
Hi
You will get the indices of the elements, in the order of sorting from the second For Loop..use these indices to identify the index of the last element that was added.
attached is an image of how it should work
Freelance_LV
TestAutomation Consultant
(2,595 Views)
"You are taking the size of the array and inserting the new element at that index this is nothing but build array and a simple build would do this."
thanks for the tip ^^ I've been using LabVIEW for a few mounths now but I'm still not familiar with some basic things...
"In your question I guess you are asking about the index of the element that you inserted after sorting the array, right? In this case you can compare the cluster element you are inserting at the initial with the array of cluster that you get after sorting the array. So this will give you the index of the element that you are inserting initially."
I did it and it works fine, see attached image
"You will get the indices of the elements, in the order of sorting from the second For Loop..use these indices to identify the index of the last element that was added."
it works also very well !
thanks for both answers, my main VI now works as expected 😛
(2,584 Views)
