sound card, output separate sound in left and right channel?
Dear all,
I'm working and modifying the  "Generate Sound.vi"
It works fine, however i would like to control what goes out in the left vs the right audio channel.
Going down in the blockdiagram, and the sub vi:s i actually get lost where the 'mono' rectuangular tone duplicates to stereoright and left channel.
Any ideas, inputs are welcome 🙂
(4,620 Views)
Accepted by Izze2000
You just have to use an instance of the the Sound Output Write that has a 1D waveform data type input (i.e.  Sound Output Write (DBL)). Each element in the array would correspond to a channel. You change the type by right clicking on the function and doing a 'Select Type'. Oviously, the waveform generation in the example would have to be modified as well.
(4,600 Views)
Dennis,
Got it, and it is working!! Smiley Very Happy
Many thanks!
(4,588 Views)
hola a todos quiero graficar los canales R y L  de  audio de mi mydaq
estoy utilizando un ipod
graciAS A TODOS LOS K NO SE GUARDAN EL CONOCIMIENTO
Smiley Wink
(3,702 Views)
