split and group string
@icycool wrote:
..btw can u attach ur example vi.
You did not say what LabVIEW version you are using....
Message 11 of 20
(1,694 Views)
ouh..im using labview 2009
Message 12 of 20
(1,688 Views)
After reading through the post, I created a quick VI based on the image that was previously posted.  Please see attached VI.
Jake G.
Applications Engineer
Message 13 of 20
(1,660 Views)
i cant open ur vi. as it is version 10 and im version9 =(
Message 14 of 20
(1,643 Views)
I'm sorry, my mistake.  The LabVIEW 2009 version of the VI is below.
Jake G.
Message 15 of 20
(1,633 Views)
thanks for vi. TheTician..one thing i forget..my input is in HEX..and i want the output for each of them to be converted to decimal..how do i make it then?
Message 16 of 20
(1,611 Views)
If the input is a raw binary string, here's one possible solution. You did not really specify the output type, modify accordingly if you want a different output (e.g. format to a decimal string). Questions?
Message 17 of 20
(1,596 Views)
thanks altenbach..i want my output in decimal only..so then i will delete the output in hex
another thing,i try to make four 1D array for each of my element which is 1111,2222,3333 and 4444 but it didnt work..can u help me
Message 18 of 20
(1,583 Views)
Accepted by icycool
Here's one possibility. It's a bit inelegant so try to find a better way. 🙂
Message 19 of 20
(1,577 Views)
no problem..i'll change it according to what i need..thanks altenbach..u've been a great help 😃
Message 20 of 20
(1,570 Views)
