square root symbol in front panel
Hi pcs,
the Windows tool CharacterMap shows you all chars and their codings!
Doh…
Message 11 of 26
(2,556 Views)
Hi GerdW,
I had tried that too. but the multiple font problem persists. in Application font it converts to the 'O' with two dots over it. unless i find a way to have two fonts coexist within the same string, i dont think its gonna work!
Thanks.
Message 12 of 26
(2,547 Views)
Hi pcs,
what's the problem to show two strings next to each other as mentioned (and demonstrated) before?
Message 13 of 26
(2,540 Views)
Dear GerdW,
I am sorry, but which one are you referring to?
Just to clarify my issue, I ve got the front panel display of the label/caption fixed. Now I need the sqrt symbol inside the box. It should be programmatically written. So if I initialise the string constant as sqrt(3)  , it gets converted to Ö3. (Ö is the application font equivt of sqrt ).Pls see the pictures of sqrtinit and sqrt_revert situations i ve posted. (I tried to paste the root symbol where you see the 'sqrt' text and it reverted to Ö ).
Thanks.
Message 14 of 26
(2,525 Views)
Hi pcs,
You didn't say so before...
Nevertheless: set the font to Symbol and write "Ö3" into the string indicator:
Message 15 of 26
(2,519 Views)
Dear GerdW,
Could you write 1.2Um/sqrt(3) ? what I understood is that fonts for all the characters in a text box has to be same. there can not be multiple fonts. could it be so? if yes, i m doomed!
pls take a look at the snap.
Message 16 of 26
(2,517 Views)
Accepted by pcs82
Hi pcs,
the picture in your first post does show only the label of some indicators to have sqrt in their text. You should have mentioned earlier that you wanted to write into the string indicators on the left side of that picture!
Set the font for the needed chars:
(Use properties Text.Selection and Text.Fontname!)
Message 17 of 26
(2,513 Views)
Hello Gerd,
I succeeded in setting the properties of the display string, but when I assemble individual strings to a 1D array of clusters (which is the format in which I need them to be displayed,) it seems to lose the property. attaching the vi. I tried to see if there are any options for property control of individual elements of the array. Couldnt find anything.
Could you pls look in the vi?
Thanks!
Message 18 of 26
(2,491 Views)
Hi pcs,
in an array all elements share the same properties, they only differ in value!
Use a cluster instead - just to present a nice UI to the user...
Message 19 of 26
(2,484 Views)
Hi pcs82,
As  GerdW said cluster are better options than arrays, below i am attaching a vi in which i have modified your code with clusters hope it works.
Message 20 of 26
(2,475 Views)
