starting LabVIEW.exe with alternative INI file
Is it possible to start LabVIEW with an alternative INI file?
Usually LabVIEW.exe takes the INI file which is in the same folder with the same name:
   "C:\Program Files (x86)\National Instruments\LabVIEW 2020\LabVIEW.exe" uses "C:\Program Files (x86)\National Instruments\LabVIEW 2020\LabVIEW.ini"
What I'd like to do is to give LabVIEW.exe another INI-File as command line parameter. E.g.
   "C:\Program Files (x86)\National Instruments\LabVIEW 2020\LabVIEW.exe" "C:\LVProjects\MyLV.ini"
If I do as described above LV opens with the standard ini and loads MyLV.ini in the notepad.
Maybe I need an additional command line parameter or maybe there is also a completly different way. Any hints are welcome.
Thank's you!
(468 Views)
Accepted by Andi_S
You should include -pref
"c:\Program Files\National Instruments\LabVIEWxxxx\LabVIEW.exe" -pref "c:\MyProject\labview.ini"
See https://labviewwiki.org/wiki/Custom_LabVIEW_configuration_file
(450 Views)
It's working! - thank you !! 😀👍
(317 Views)
