09-22-2016 07:50 AM
Hey all,
I'm using LabVIEW 2016 that I recently installed, and I've noticed something I can't remember ever having an issue with before:
I (somewhat) frequently want to place a subVI onto a calling block diagram by "left-click and hold" on the subVI icon, and dragging it to the intended to be caller's block diagram.
Fairly consistently this fails even though the mouse icon shows the expected "+" symbol while dragging, when I let go of the left mouse button, nothing happens, the subVI does not drop.
I've tried to nail down the root of the problem (playing with the path that I drag the cursor over by avoiding certain areas, what bounds I exit (top window border, left, right, avoiding the subVI toolbar while dragging, etc. etc.) but every time I think I observe a pattern, a couple of drag-copy's later, it fails, even if I did not change the path.
I've also tried playing with relative window positions (e.g. the subVI window overlapping or not overlapping the drop-target window).
Am I just going crazy or did something happen to this functionality in 2016? Has this always been an issue and I have just somehow changed my workflow in a subtle way that now makes me more suceptible to this issue?
Has anyone else seen this behavior and/or figured it out?
09-22-2016 09:20 AM - edited 09-22-2016 09:21 AM
I've seen stuff like this when LV wasn't installed as admin or run as admin.
09-22-2016 10:24 AM
I'm fortunate(?) enough that I'm my own local admin on my job computer. 🙂
01-26-2017 11:15 AM - edited 01-26-2017 11:29 AM
NI, have you found a solution to this yet? I'm noticing this too and am an admin. A bit annoying.
EDIT: I've noticed that it usually happens when I click and drag the icon from the block diagram window. Front panel icon works OK.
In LabVIEW 2015 SP1 you can click and drag from either the FP icon or BD icon. Looks like a LabVIEW 2016 bug.
01-26-2017 11:31 AM
I've tried this too and get the same behavior on my machine. 2015 works, 2016 does not. Have you guys found a workaround for this?
01-26-2017 12:08 PM
It seems to be primarily an issue if I try to drag-drop the icon from the 'block diagram window'. If I drag the icon from the front panel window it seems to 'always' work.
So whenever I encounter this issue these days (which is NOT 100% of the time), I just grab it from the FP and drop it where I need it and go about my day. My impression is that NI is unlikely to fix this annoyance since the next version of LV has a completely re-worked IDE anyway.
01-26-2017 01:08 PM
Theoritically 2016 SP1 should come out any day now. Maybe we'll get lucky and see it fixed there. It's frustrating that a core capability that has been there for a long as I can remember (back to 5?) all of the sudden no longer works. Especially since we will likely be using 2016 for several years here.
01-26-2017 01:37 PM
Oh I hear you! No argument from me. Still, for me it went from a major source of frustration to a minor once I found out how to reliably work around this new 'feature'. 😉
As far as my comment on them fixing it or not, that may just be me moderating my own expectations on this, but you are correct, it is possible a SP1 could fix this. . . Speaking of, does anyone know if SP1 schedule might have changed when they moved NI Week to May and the teased product release they have planned?
02-08-2017 08:19 PM
I have noticed this as well. I would consider it a bug. Someone from NI please comment and issue a CAR for this.
(Why would functionality like this disappear from 2015 to 2016?)
02-09-2017 11:32 AM
Hi everyone,
Thanks for pointing this out. I was able to replicate it as well. As far as I can tell, this is indeed a bug, not a "feature." I'll go ahead and file for a CAR.
I've tested it on Windows 7 64-bit. Are you guys using anything else? I can add those as OSes we've seen it on.
Also, for me it always works from the front panel, and from the block diagram if I try it twice. (If I try it four times in a row, it works on tries two and four.) If you guys are seeing anything else in terms of patterns, let me know. I'll try to replicate those patterns as well.
