synchronize two devices
Comment synchroniser deux périphériques, l’un étant le périphérique d’acquisition de données NI USB-6212 et l’autre un capteur de température pour National Instruments
(315 Views)
Hi khelifa,
@khelifa18 wrote:
How to synchronize two devices, one being the NI USB-6212 data acquisition device and the other a temperature sensor for National Instruments
Which "temperature sensor for NI" are you talking about?
Are there any (physical) connections between your "two devices" that would allow/support syncing them?
Please provide as much information as possible!
(308 Views)
Hello ,
The temperature sensor is TCD1 and I use NI USB-6212 to measure voltage and irradiation.
There are no physical connections between the devices.
Thank you ,
Khelifa
(292 Views)
Accepted by khelifa18
Hi khelifa,
This is what I found about TCD1: is this your sensor?
Can you provide more information how you access the temperature value?
(269 Views)
