table format
Hi all,
I have this requirement where I would like to control the data format of individual cells of a table. Look at the following table.
is it possible to have the no. of measurements to show only integer values ( 1 2 3 4 .....etc ) instead of ( 0.00000, 1.00000 , 2.00000 ) and keep the format of second column. so I ideally I would like to have following table.
Rajnikant Singh
Iowa State University (Research Assistant)
Message 1 of 9
(3,327 Views)
@raj_iastate wrote:
Hi all,
Get away from using that express VI and convert the numbers to strings yourself.  You will have fine control over how the resulting number(s) will be converted.
On a different note... CLAD... really???
Bill
CLD
(Mid-Level minion.)
Message 2 of 9
(3,322 Views)
I would appreciate if you don't waste my time with your answers.
Rajnikant Singh
Message 3 of 9
(3,313 Views)
It's not a wastet of time.  I gave you the answer, stright up.  Do the conversions yourself and you have much finer control over how the resulting string is formatted.
Bill
CLD
(Mid-Level minion.)
Message 4 of 9
(3,308 Views)
Hmm, I guess I won't waste your time either.  Why ask the question if you don't want the answer??? Smiley Frustrated
Message 5 of 9
(3,293 Views)
Accepted by topic author raj_iastate
A Table Indicator is a way of displaying a 2-D array of strings. As billko wrote, if you replace your Express Table with a normal table indicator, then you can format the data into a string array any way you like, and it can be different for each cell if that's what you want.
Message 6 of 9
(3,290 Views)
thanks
Rajnikant Singh
Message 7 of 9
(3,284 Views)
Here's an example of how you can do it.
GCentral
Message 8 of 9
(3,276 Views)
can you please send me the vi ? and I gave a kudos............thanks for the reply.
Rajnikant Singh
Message 9 of 9
(3,239 Views)
