tdms file edite
Hi, everyone!  How can I replace some certain raw data in a tdms file and to make sure it can be read through  tdms_read.vi? I tried to edite it by excel, but after changing the data it can only be saved as xls file.
(3,010 Views)
Accepted by ne_meiju
You cannot manually edit the tdms file instead you can write a small VI to read the content and then edit and write it back.
(2,994 Views)
Hi P@Anand, thanks for your advice, I'll try another way~
(2,987 Views)
