temperature data acquisition from an engine using microcontroller and how to use the data coming in serial communication to ni labview
HI...
i have developed data acquisition system wherin a temperature values are sensed by microcontroller and transmit the data to pc using serial communication my problemis i want labview file which reads the serial communication data and process it .
my data acquisiton just performs acquiring the temperature comparing the data if it exceeds certain value shut down the engine... kindly do the need
mk...
(3,494 Views)
All further discussion will take place here http://forums.ni.com/ni/board/message?board.id=170&message.id=497812
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,466 Views)
