to store
sir, while i am reading data from one file by "read from measurement file", it reads some data and plotted as graph then said error as
Error 100 occurred at read from measurement
file-->read waveform.vi
Possible reasons(s):
LabVIEW : file contains erroneous data.this normally is a user
data file.
i dont understand what is the error in there!
if i continue the reading ,finally it reads only some part of the data alone....
help me to rectify this sir
thank you.
Message 11 of 23
(961 Views)
Hi kausi,
that error message is quite clear: the file doesn't contain the expected data...
To analyze that problem you should attach your VI as well as an example data file!
Message 12 of 23
(957 Views)
sir, i used low pass filter , cutoff freq 5, eliptic, order 5.
if i continued after error occured, it displays only the data at time 159sec to 364sec(x axis)
thanking you.
Message 13 of 23
(948 Views)
Hi kausi,
I will repeat myself:
Message 14 of 23
(945 Views)
sir ,my data file is in .lvm extension format...it does't attaching "The file does not have a valid extension for an attachment"
so i am sending my data file as in xcell format...
thak you
Message 15 of 23
(937 Views)
Hi kausi,
ever tried to attach a ZIPped version of your lvm file? Please do so!
Message 16 of 23
(941 Views)
Message 17 of 23
(939 Views)
Hi kausi,
yes, ReadMeasurementData complains about mangled data file.
How did you create it?
Message 18 of 23
(936 Views)
sir,
by using pressure sensor i acquired our radial artery pulse through 9205 DAQ card and i stored data by write to measurement file .
but some files read correctly without errors, is there any setting changes needed in configure write to measurement file?
Message 19 of 23
(932 Views)
sir,
or otherwise is there anything needed to change in configure read from measurement file?
Message 20 of 23
(928 Views)
