two ximea cameras can't been seen by LabVIEW
We are trying to run two Ximea USB3 cameras, but cannot get LabVIEW or NI MAX to see them both at once.  Is it because we are using a USB3 splitter (only one port on the 9GB RAM machine)?  Or an IMAQ issue?
Andrew
(3,333 Views)
You should try to look around here. Maybe you can find some reusable VIs for your project.
https://decibel.ni.com/content/docs/DOC-29025
+++ In God we believe, in Trance we Trust +++
[Hungary]
(3,317 Views)
Hi Andrew,
Can you tell me what version of LabVIEW and the IMAQdx srivers you are using?
Chris
National Instruments - Tech Support
(3,286 Views)
I'm assuming LV 2013 and the August driver release?
Chris
(3,283 Views)
Hi Chris, and thanks
It's actually still LV2011 - I see that the Ximea VIs referred state 2012 requirement though.....
Andrew
(3,276 Views)
Hi Andrew,
It seems that full support for USB3 has only recently been added:
http://www.ni.com/white-paper/14308/en
The article explains how to get things working. Let me know if this helps.
Chris
(3,273 Views)
Thanks Chris, helpful.
I take it I will need to upgrade to get going.
Any idea if I can upgrade only my Vision software but keep LV2011 going?
Andrew
(3,252 Views)
