08-13-2013 11:23 AM
We are trying to run two Ximea USB3 cameras, but cannot get LabVIEW or NI MAX to see them both at once. Is it because we are using a USB3 splitter (only one port on the 9GB RAM machine)? Or an IMAQ issue?
Andrew
08-13-2013 02:27 PM
You should try to look around here. Maybe you can find some reusable VIs for your project.
https://decibel.ni.com/content/docs/DOC-29025
08-14-2013 09:55 AM
Hi Andrew,
Can you tell me what version of LabVIEW and the IMAQdx srivers you are using?
Chris
08-14-2013 10:00 AM
I'm assuming LV 2013 and the August driver release?
Chris
08-14-2013 11:03 AM
Hi Chris, and thanks
It's actually still LV2011 - I see that the Ximea VIs referred state 2012 requirement though.....
Andrew
08-14-2013 11:33 AM
Hi Andrew,
It seems that full support for USB3 has only recently been added:
http://www.ni.com/white-paper/14308/en
The article explains how to get things working. Let me know if this helps.
Chris
08-16-2013 08:35 AM
Thanks Chris, helpful.
I take it I will need to upgrade to get going.
Any idea if I can upgrade only my Vision software but keep LV2011 going?
Andrew
