01-27-2016 06:47 AM
i already uninstall them by using MSI Blast.
Thank you all.
03-08-2019 02:00 PM
Please send me MSI Blast because I am facing the same problem now with Labview 2018 in Win 10.
03-09-2019 01:49 PM
Before you run MSBlast or any other Registry Fiddler, I strongly recommend that you do the following:
I've done a "forced uninstall" twice, on two different machines. When that totally corrupted Windows, I was forced to reformat the C: drive and spend a day or two rebuilding my Desktop and my Laptop. You might get "lucky", but Be Prepared ...
03-11-2019 05:57 PM
Hi Saad82,
The MSI Blast isn't a commonly used utility to fix installation problems. If you'd like to talk with an applications engineer at National Instruments about your particular use case, you can create a service request. Otherwise, it might help you find a fix if you post your issue on a new discussion thread (and reference this one).
06-14-2019 11:20 AM - edited 06-14-2019 11:22 AM
Please send me MSI Blast because I am having the same issue now with Labview 2018 and 2017 in Win 10.
06-15-2019 01:53 AM
These LabVIEW versions use the NIPM (NI Package manager) installer, not MSI (the microsoft installer), so what makes you think some ancient software with the "MSI" term in the name would even know what to do?
Do you still have the package manager installed? Maybe you can try following these instructions.
Tell us exactly what you already did, what you tried, and what kind of errors you got?
